What the
Results 1 to 4 of 4
Thread: What the
  1. #1
    Join Date
    Mar 2015
    Location
    Washington
    Posts
    3,104
    What the
    Hell is up with this front axle...???https://www.ebay.com/itm/1966-Chevro...UAAOSwYA5eGMvE
    Lash...Washington Chapter and Member...Mean Old Bastards Club
  2. Remove Advertisements
    GasserHotRods.com
    Advertisements
  3. #2
    Join Date
    Feb 2011
    Location
    Portland
    Posts
    12,423
    It appears to be a dropped tube axle that someone decided it wasn't strong enough, so they added a crap load of extra steel to box it. Or maybe they narrowed it to fit the Nova and then did all this extra metal to make it withstand Dukes of Hazard type jumps? Uglier than sin, and I'd replace it if I owned the car as fast as I could!
  4. #3
    Join Date
    Mar 2015
    Location
    Washington
    Posts
    3,104
    I figured that the axle bent and he crapped it back together...looking at it more closely and seeing where the spring plates are welded on ...way out board, it maybe that he tried to make a way short axle work, it looks like a T bucket axle witch is way to light duty for the Mustang...nothing like an I beam
  5. Remove Advertisements
    GasserHotRods.com
    Advertisements
  6. #4
    Join Date
    Feb 2011
    Location
    Portland
    Posts
    12,423
    Didn't think about he might have widened it? That's certainly another possibility. But regardless of why he did it, it sure seems like a huge amount of work for the small savings. (if any savings?)
  7. Remove Advertisements
    GasserHotRods.com
    Advertisements
Posting Permissions
  • You may not post replies
  • You may not edit your posts
