dsb's chevy gasser build - Page 25
Page 25 of 26 FirstFirst ... 1523242526 LastLast
Results 241 to 250 of 253
Thread: dsb's chevy gasser build
  1. #241
    Senior Member dsb's Avatar
    Jul 2013
    St. Louis, MO
    561
    surprised to see that the studs hadn't been made to accept an allen wrench to install them with. I'm thinking that whoever installed those didn't want to go the expense of having the boss' machined flat. The other thing is that most of the time when you go to the expense of the machine work most guys will also install pushrod guide plates. If you're going to use the ones you have I'd definitely use red loctite as you mentioned. My other thought is that since the bosses weren't machined they were probably drilled and tapped by the dude you got them from. You really want to make sure when you install them that they have a nice tight fit and there's no wobble as you're screwing them in other wise there's a good chance you're going to be pulling a stud out.
    Thanks for the tips.
    Dave
    I wish I was half the man my dog thinks I am!
  3. #242
    Jul 2013
    St. Louis, MO
    561
    What do you think of the lettering?
    Click image for larger version.
    Dave
  4. #243
    12,451
    Quote Originally Posted by dsb View Post
    Too early!
    It looks good though.
  5. #244
    6,745
    Hey Dave sorry I didn’t get back to you today. I was real busy at work and didn’t see your post. I found this typical screw in studs and guide plates. Just a heads up, if you do this setup you need hardened pushrods.
  6. #245
    Jul 2013
    St. Louis, MO
    561
    Too early!
    Too early? Why? OK, I snapped pics of where the studs go into the heads. Thoughts?
    Dave
  7. #246
    1,820
    Dave
    to me the bosses appear to be non machined. In the last photo is the stud bottomed out or just not screwed in all the way? They should be run all the way down to the stop.
  8. #247
    Jul 2013
    St. Louis, MO
    561
    That is the one that was backing out as I loosened the nut. I am just going to cover them in red loctitie.
    Dave
  9. #248
    6,745
    When you put them back in it should be torqued.
    Rocker Studs (screw-in) Engine Oil 50 ft-lbs.in)
  10. #249
    3,117
    Dave where did you get the engine from....was it some thing you bought that was already built...if so I would pull it down and check every thing
  11. #250
    Jul 2013
    St. Louis, MO
    561
    The whole lower end was gone through just before I moved. I got the heads separately. My engine guy looked at them and pronounced them good. Only because the screw in studs were out at the time. The heads came off a running corvette. I am surprised they do not have a way to torque them down. Maybe I will set up a jam nut type situation and torque them.
    Dave
