powerglide shift lock
Results 1 to 2 of 2
Thread: powerglide shift lock
  1. #1
    Junior Member
    Sep 2018
    16
    Will local tracks,NHRA, IHRA,etc allow reverse lock on shifter such as old -fashioned barrel bolt gate lock? I am running powerglide and want to have option to alter shifters to fit my needs. This method was used years ago.
  3. #2
    Senior Member
    Aug 2015
    Brooksville Ky
    589
    As long as you can't stick it in reverse, your good. I used to have an old shifter with a spring loaded deal that you had to pull to put it in reverse. Passed fine.
  4. Remove Advertisements
