'39 Chevy Coupe project. - Page 100
Page 100 of 103 FirstFirst ... 50909899100101102 ... LastLast
Results 991 to 1,000 of 1027
  1. #991
    12,343
    that interior looks awesome Vall. Great job.
    Thanks Mario! Means a lot coming from you, as I know the quality of work you do!
  3. #992
    6,645
    If you need something on the Chevy check these guys out they did good by me on my 35.
    they carry a lot of Chevy stuff.
    http://www.aaaparts.cwmax.com/
  4. #993
    12,343
    Thanks Mario! Not much needed at this point, but I see things I would have bought from them had I not already gotten them.
  5. #994
    12,343
    In my continued effort to make the '39 a cruiser that I can take long drives with, I installed a 12 v. cigarette outlet. Maybe they call them something different today? But I had existing holes in the inset below my toggle switches, so I purchased one with a black rubber cover so I can run a phone charger, GPS, or whatever I need to use this style receptacle. Lots of spare circuits with my 21 circuit fuse block, so might as well use them up!
  6. #995
    12,343
    I like vacuum gauges! I tune most of my rides based on vacuum readings as they really tell what the engine and carbs are doing. I bought a vacuum gauge about 3 months ago, and then found a dash pod to put it in, but had to wait 2.5 months for it to be delivered!! From China of course, as I couldn't find any in my searches.
    I installed it yesterday and fired the '39 up to check engine vacuum. To my surprise (and shock) my engine is producing almost 20 inches of vacuum! It drops to 10" revving the engine, but that's normal. Never dreamed the big Howards cam would put out so much vacuum! I avoided using a power brake booster, as I figured it wouldn't work. Now I may reconsider that thinking, and maybe consider adding one in the future.
  7. #996
    6,645
    Now you’re showing your ole school my friend. Lol
  8. #997
    1,743
    As with
    you Vall I run a vacuum gauge also. I ran a line between the 2 carbs Click image for larger version.
Name:	53 Tunnel Wedge.jpg
ID:	103185 with an adaptor for the gauge. After the motor warms up I move the timing until I get the best reading. Also like you I was really surprised at the 20-21 inches of vacuum I get with the Big Mutha Thumpr cam.
  9. #998
    6,645
    [QUtOTE=sbauman2;261583]you Vall I run a vacuum gauge also. I ran a line between the 2 carbs Click image for larger version.
ID:	103185 with an adaptor for the gauge. After the motor warms up I move the timing until I get the best reading. Also like you I was really surprised at the 20-21 inches of vacuum I get with the Big Mutha Thumpr cam.[/QUOTE]
    Steve that sounds like a good idea. I’m wondering though. The last time I put a T in a vacuum line I got a pulse in my Holley that I wasn’t aware of. Carb was bleeding down at an idle like a high float level. I replaced the carb and still had a bleed down and found out it was a vacuum line T causing the issue. Since then I swore to never do that again.
    have you ever experienced that situation?
  10. #999
    12,343
    Doesn't the vacuum secondary balance kit basically do the same thing? Whenever I've run dual carbs that have vacuum secondaries I've installed the balance kit, which syncs the two carbs together, and not had any issue.
  11. #1000
    12,343
    The Big Mutha Thumpr cam I had in my Falcon produced very low vacuum for my BBC. It idled around 10", and rarely got above about 13 in. even when I was decelerating. It's one reason I went with the Howards roller Rattler cam when I did this engine.
