57 Ford Custom - Page 2
Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 39
Thread: 57 Ford Custom
  1. #11
    Member fiftythreechevy's Avatar
    Jul 2018
    Washington State
    35
    The smaller 28 spline 9" is indeed the weaker axles, but new side gears and axles will fix that.
    So I can put in the 31 spline axle and new side gears in the same housing? What about the bearing size, will the larger bearings fit in the housing?
  3. #12
    Senior Member manicmechanic's Avatar
    Nov 2015
    Earth, I think?
    580
    KOOL KAR!! Great save! Was looking for one before I got my Austin. But prices wear ridiculous, on crap.
    Hidden Content I have no extra cigarettes, money, beer or pot. But I do have extra bullits. Scott
  4. #13
    12,578
    Quote Originally Posted by fiftythreechevy View Post
    Not sure. You might need either special bearings, special side gears, or some work to use the larger 31 spline axles. 9" Fords aren't cheap to rework. Even when someone gives you one for free, it can cost more to make it work than buying a different axle. I had a 9" for my '63 Falcon, but sold it when I found out what I'd have to put into it.
  5. #14
    Jul 2018
    Washington State
    35
    I've been looking at the 8.8 Ford. 31 spline, limited slip, disc brakes, and 4.1 or 3.73 gears in some of the explorers. That might be the way to go.
  6. #15
    12,578
    Impossible to beat at the price. They are a copy of the 12 bolt Chevy rear axle, and even share numerous parts. Built in the same plant too.
    The Explorer and 4x4 Rangers have an offcenter pinion, with a short side axle. They are about 59.5"wide, and can be very cheaply narrowed to 56.5" by simply cutting the long side down and swapping a factory short side axle in. That narrows it, plus centers the pinion too! The 56.5" width works very well for a lot of 50's and 60's tubbed cars, or cars with big meats that need a narrower rearend.
  7. #16
    Jul 2018
    Washington State
    35
    I think thats the way to go since the stock width of my car is 57.5 inches. I found one locally for 225 , which isn't much more than our local pull and save.
  8. #17
    12,578
    Our Pick N Pull will sell the short side axles from a non posi for $20. They work on either limited slip or open, so no issues. Easier to remove from a open differential. Then it takes a 2 7/8" approx. cut in the tube to use the short axle on the long side after shortening.
    I use a big Ridgid tubing cutter to get a perfectly straight cut, and then the tube can be butt welded back together. I tack with my mig, and then take the axle to my welder to have him get a really top notch strong, and great looking weld. He does them for about $20-$25.
  9. #18
    Jul 2018
    Washington State
    35
    1946 Austin you are full of great information! I think that is definitely the way to go, thank you for the help.
  10. #19
    Jul 2018
    Washington State
    35
    Okay, so I took two years and built a shop, put a lift in, and I'm back up and running. I got Jezebel into the shop this weekend. Since then I sourced an 8.8, a floor pan from a 58, a 460, and the 69 460 heads. The floor is pretty gone and the rockers are shot. I'm contemplating cutting it all out in one piece and putting the new piece in including the firewall. I would weld in braces first in the body. Anyways, here's a few pics.
    Nick
    There was never a horse that couldn't be rode, there was never a cowboy that couldn't be throwed.
  11. #20
    Jul 2018
    Washington State
    35
    Computer worked, phone not so much. Click image for larger version.
ID:	103813Click image for larger version.
ID:	103815Click image for larger version.
ID:	103817Click image for larger version.
    Last edited by fiftythreechevy; 09-14-2020 at 12:20 AM. Reason: got pics to upload
    Nick
