'35 Plymouth coupe - Page 3
Page 3 of 17 FirstFirst 1234513 ... LastLast
Results 21 to 30 of 167
Thread: '35 Plymouth coupe
  1. #21
    Join Date
    Feb 2011
    Location
    Portland
    Posts
    12,323
    Here's what the '36 frame horns looked like originally. Not very pretty for a fenderless car.
    There's a bunch of that X member in the middle that's going to need to be reworked! Not sure that trans tunnel will work and allow servicing the 4 speed either, as it might require pulling the engine/trans if it's trapped in there. So we may end up removing the whole X member and replacing it with round tube framework to make it cleaner, and easier to build around.
  2. Remove Advertisements
    GasserHotRods.com
    Advertisements
  3. #22
    Join Date
    Feb 2012
    Location
    So.Cal.
    Posts
    1,732
    I absolutely love the car in the video; especially the body, just the right amount of patina.
    Vall, you mentioned that your friend wants to go with wider front tires. Do you mean wider than the ones on the car in the video or wider than what he has now.
    Steve Hidden Content in sunny So Cal
  4. #23
    Join Date
    Feb 2011
    Location
    Portland
    Posts
    12,323
    Quote Originally Posted by sbauman2 View Post
    No, the narrow 4" Cragars and tires we have on it now will be what he's running. I mentioned the coupe in the video has wider tires, but his wont. We like the skinnies up front!
  5. Remove Advertisements
    GasserHotRods.com
    Advertisements
  6. #24
    Join Date
    Feb 2011
    Location
    Portland
    Posts
    12,323
    We spent another day on the '36 Plymouth, but at the end of the day it didn't look much different! We got the frame bushed for the rear mounts on the hairpins, and got the panhard bar cut to length and a frame mount built for that also. Mike got his upper shock mounts to weld to the frame, but they need reworking to make them fit. Did some layout of the rear axle and head scratching on how to cut and box the frame to clear the rear hairpins/ladder bars. I did talk him into going coilovers in the back also, so that made me happy!
    Click image for larger version.
    The little panhard bar, and the donor chrome brackets I hacked off another project.
    The rear ladder bars.
  7. #25
    Join Date
    Feb 2011
    Location
    Portland
    Posts
    12,323
    Been back on my buddy's '35 Plymouth coupe in the last couple weeks. We've made good progress, and a couple significant forward steps. Last week I got the motor and trans mounts built for the SBC and Super T10. He had an old engine and 4 speed to use for mockup, so we have them sitting in the frame last week.
    Yesterday I got the 8.8 Ford 4.10 posi located, and the pinion angle set, so I could mock up the ladder bar and coilover shocks. Got the brackets tacked to the axle, and the front mounts built to attach the heim joints for the front of the ladder bars.
    Once the rear axle was located we stopped, and decided it was time to remove the body so we could finish the upper shock mounts, and panhard bar. Just too difficult doing it all from under the car. To our surprise the body bolts had numerous heads snapped off, and others appeared to be missing. I put a jack and a wood block under the body, and after raising it a bit we saw the body pop loose from the frame! Someone had already removed every bolt, or snapped them off. So the body removal was an easy task to that point. We rigged two hoists through the rafters at the back of his garage, and raised the body as high as possible. Still not enough clearance, so we dropped the frame down off blocks, and directly on a pair of dollies to let is roll forward.
    Next week we'll get the rear axle back under the car for the 3rd time, and then build up the panhard bar, and upper shock mounts for the coilovers. After that we can locate the Vega box and complete steering to the box.
    Try to get more pictures next week also, so it wont just be talking about it here.
  8. #26
    Senior Member manicmechanic's Avatar
    Join Date
    Nov 2015
    Location
    Earth, I think?
    Posts
    580
    Oh! You mean the "Graffiti" '55.
    Hidden Content I have no extra cigarettes, money, beer or pot. But I do have extra bullits. Scott
  9. #27
    Join Date
    Nov 2015
    Location
    Earth, I think?
    Posts
    580
    According to "Posies" Don't use "hairpins" on tube axles.
  10. #28
    Join Date
    Feb 2011
    Location
    Portland
    Posts
    12,323
    Quote Originally Posted by manicmechanic View Post
    ????????? Not sure what that has to do with the coupe? Went over my head.
  11. #29
    Join Date
    Dec 2012
    Location
    Long Island, NY
    Posts
    6,632
    Car is so cool for gasser style. Love the body style. I think cleanly removing the x frame and round tube replacement is a good idea. I used 2x4 tubing but I wish I used the round tube being I had purchased the tube bender. Anyway water under that bridge. Great job guys. Don't forget emergency brake lever placement during the frame build so you might retain stock position by the center dash. I love that look.
  12. #30
    Join Date
    Feb 2012
    Location
    So.Cal.
    Posts
    1,732
    Scott might be referring to the same car being used in both movies. At least I remember reading the same 55 was used in both movies with modifications for the time period.
  13. Remove Advertisements
    GasserHotRods.com
    Advertisements
Posting Permissions
  • You may not post replies
  • You may not edit your posts
