1935 Chevy Gasser - Page 31
Page 31 of 31 FirstFirst ... 21293031
Results 301 to 303 of 303
Thread: 1935 Chevy Gasser
  1. #301
    6,332
    I got back at it tonight. Im moving real slow. But Im moving. I moved the rear on to the jack stands by myself I might add. I pulled the cover and unbolted the c-clip eliminators. Letting the grease drain real good and Picking up the carrier removal tomorrow. The carrier is a Moroso Brute strength unit. Good for 557 to 456 without an issue. I dug out my pinon flange hold down tool to break the nut loose. I gotta say I used it a bunch of times and it was free and free is for me.
    Attached Thumbnails Attached Thumbnails IMG_4964.jpg   IMG_4963.jpg   IMG_4962.jpg   IMG_4961.jpg
  3. #302
    2,801
    I moved the rear on to the jack stands by myself I might add.....Dont bust a nut...you only got one pair...you do not want the Asian name of.... One Nut Low
  4. #303
    11,825
    With the reports I see of cold weather around your area Mario it's good to see you can still get to the garage to work on the '35! Hope it goes well for you! Call your son for some help if needed! Don't be like me and get a hernia. I've had one fixed about 6 years ago, and need to get another done soon!
