Finally got a duece... - Page 3
Page 3 of 11 FirstFirst 12345 ... LastLast
Results 21 to 30 of 110
Thread: Finally got a duece...
  1. #21
    Administrator mt94ss's Avatar
    Join Date
    Dec 2010
    Location
    Ridgefield, WA
    Posts
    1,594
    Cap?n, I restore tubs as a job. Clawfoot tubs are fun and I usually do them in my booth.
    Liberty, In God We Trust, E PLURIBUS UNUM
    Watch it tilt! => Hidden Content
    Watch my engine => Hidden Content
    My GMC Hidden Content
    Hidden Content
  2. Remove Advertisements
    GasserHotRods.com
    Advertisements
  3. #22
    Senior Member Cptnbob's Avatar
    Join Date
    Jan 2012
    Location
    Hubert, NC
    Posts
    1,502
    I gottcha! A lot of people are going back to the retro look these days.
    Robert
    "Stick'er to the floor and hold'er straight" Hidden Content
  4. #23
    Join Date
    Dec 2010
    Location
    Ridgefield, WA
    Posts
    1,594
    While I had a bit of time today I decided to weld up my fix for a cross steer on my Deuce. I used the kit from Speedway but for a top steer the tabs were bent the wrong way. So I ordered two kits, one with just the single hole and the other for steering that has one with two holes.
    I just cut off the tabs on the steering arm and mated it back to back with the other arm. I ground a 45* all Around where I was gong to weld. You can see the photos, it turned out great. And raised a bit is perfect.
    The welds almost looked too god to grind off but I’m going to powder coat them Chrome.
    Attached Thumbnails Attached Thumbnails 6B1653FB-39EF-4418-9641-D11B54B0783C_1512975026664.jpg   187A38D7-3F5E-4AAF-9859-2D0C09AEF321_1512975280118.jpg   8C0A5AB5-5B8A-4F83-A0C6-886C1101B8BB_1512975293470.jpg   9B266C2C-E223-4D56-ADF4-FAD055E11DB9_1512975317201.jpg   67482DB2-4CF5-4243-96A5-F894755BBC29_1512975334016.jpg
    Hidden Content
  5. Remove Advertisements
    GasserHotRods.com
    Advertisements
  6. #24
    Join Date
    Feb 2012
    Location
    So.Cal.
    Posts
    1,729
    Nice job Mike.
    Steve Hidden Content in sunny So Cal
  7. #25
    Join Date
    Feb 2011
    Location
    Portland
    Posts
    12,315
    Looks pretty darn beefy Mike!
  8. #26
    Join Date
    Dec 2010
    Location
    Ridgefield, WA
    Posts
    1,594
    Got the steering done, well mocked up. Going to get much bigger rods for the linkage.
    Also cut out the rear wells. This is the first cut so don’t freak on how uneven. I want to be able to get a good arc similar to my ‘55.
    Playing with the shrinker to maybe use these or maybe do the steel rod like the ‘55. Will see.
    Attached Thumbnails Attached Thumbnails 38E43D2C-3A6C-4F0A-AFC6-9518B952A5AD_1517196823367.jpeg   848C23A3-17D0-4F90-8B32-A67EF403D479_1517196843644.jpg   C4902062-8DFD-4389-8ECA-3CAEA2387203_1517196868054.jpeg   E12BBA1E-2E6D-44DF-A735-028EACE261B0_1517196885806.jpg
    Hidden Content
  9. #27
    Join Date
    Dec 2010
    Location
    Ridgefield, WA
    Posts
    1,594
    Also while I was cutting I had a friend over and we decided it was tine to mock up the drivetrain. I lucked out that the mounts were already V8 mounts so it was almost drop-in with the Muncie and the correct Chevy II belhousing. Headers fit great and look really good. The tunnel ram is perfect, so we cut a hole in the hood. Couldn’t use te stacks as they are too large diameter to allow the hood to open without more major surgery sonI got some small air cleaners. Looks pretty good. Will make flanges to attach the scoop. Most ofthe inner structure was left intact.
    Attached Thumbnails Attached Thumbnails 1C824CF2-CE8C-4225-A251-4CAE8DA69FAA_1517197200847.jpg   55319774-AD53-4C78-BD70-8C9C93223C88_1517197217320.jpg   7EFF9926-9868-4CAF-94B7-93BC04F62706_1517197230677.jpeg   1E656849-A107-4928-BBBE-4E0A57A7FE9D_1517197263287.jpeg   5F54F079-96A0-433B-8B2E-A4596747EFE9_1517197281883.jpg
    Hidden Content
  10. #28
    Join Date
    Dec 2012
    Location
    Long Island, NY
    Posts
    6,622
    Quote Originally Posted by mt94ss View Post
    Those uneven cuts don't worry me Mike. I know your skill level. Im sure you will make it look pretty. Love the wheel opening edge you created with the shrinker/stretcher. you
  11. #29
    Join Date
    Dec 2012
    Location
    Long Island, NY
    Posts
    6,622
    Love it Mike. I had the same issue with the surgery on the MG air cleaners. That setup looks killer and love the air in the front.
  12. #30
    Join Date
    Mar 2015
    Location
    Washington
    Posts
    3,060
    Crap how did I miss these posts...looks fast just parked in the driveway...I see its raining over on your side of the state...should be a mighty mouse with the screaming 292
    Lash
  13. Remove Advertisements
    GasserHotRods.com
    Advertisements
Posting Permissions
  • You may not post replies
  • You may not edit your posts
